easy lift
Posted: Wed Aug 17, 2005 5:20 pm
by 1988b2
i have a bronco II and i want to lift it like 2-4 inches cheaply. I thought about puttin factory ranger hiboy 2 inch blocks in the rear and 2 inch coil spring spacers in the front. Will that work out without gettin longer shocks or modifications (brake line extensions, drive shaft too short)?
Posted: Thu Aug 18, 2005 5:24 am
you are going to have to extend the brake lines get new shocks and fix the steering. you will need to have an alignment also. because you will probably have positive camber also.
if you dirve it in the street and not off road you will probably be ok for a while but if you take it off road you will be just asking for something to happen.
