Which C4??
Posted: Sun Jul 10, 2005 3:38 am
by kylebronco2
Im planning on putting a 5L into my bronco mid-august. Im running a C5 right now, from what I understand I can just swap over a bellhousing/TC from a C4 trans to get it to match up. What im not sure is what year C4 to get it from, if it matters? Also I would like to eventually use a Dana 20 twin stick t-case. To get this to match the C4 I need a C4 tailshaft from an early bronco...is that correct? Or do I have to buy an adapter for like 500$? Any info is greatly apreciated. Thanks :cool:
Posted: Mon Jul 11, 2005 9:05 pm
by gunbunny
I think that you can use any c-4 as long it was used in a 4x4 I know they were uesd in f150s untill 1980
I may be worng I am wanting to run the same set-up
Posted: Mon Jul 11, 2005 9:15 pm
by gunbunny
I have been told you have to use one out of a EB that had a D-20
guess thats what I get for thinking LOL
Posted: Sat Aug 13, 2005 12:04 pm
by Bob Myers
Any C4 bell housing will fit, if it is a case mouint it is easy, if you end up with one that mounts to the front pump housing make sure you get bolts that are the proper length.
Posted: Sun Aug 14, 2005 12:38 pm
by MikePotts
you will also need to use a torque convertor from a c-4 since the c-5 has a lockup feature, and the c-4 valve body will need to be used, again to by pass the lockup functions in the c-5 valve body. i simply used a complete c-4 i had to disassemble the trans and replace the output shaft and extention housing from the c-5 in the c-4. you can see detailed pics of my conversion here http://www.cardomain.com/ride/1804091
mike
