Hush
Posts: 2 Joined: Sat May 07, 2005 12:29 pm
Post
by Hush » Sat May 07, 2005 12:32 pm
Put a new motor in here still the exact same problems... no power , backfiring through carb now she wont even start any ideas.....
Hush
Post
by Hush » Sat May 07, 2005 12:53 pm
If thisll help I was just attempting to start it and when it decides to backfire through the carb sometimes it blows a puff of blue smoke
Posts: 588 Joined: Sun Apr 18, 2004 10:41 pm
Post
by Rockcrawler » Sat May 07, 2005 2:31 pm
did you check the timeing and the carb?
Posts: 743 Joined: Sat Jan 01, 2005 8:10 pm
Post
by ranger5.0 » Tue May 10, 2005 7:31 pm
Distributor, coil, wires???? Sounds like a weak coil. Does it get hot while trying to start or run? The pickup coil in the Distributor could be wet or malfunctioning also.
