I recently bought an 84 Bronco 2! And the heat works well, yet side windows are always foggy, is this a common thing? or do I need to wash my windows?
Thanks, I've taken into consideration all of the above, including smashing out the winshield lol. I'll bet it's the heater core, it kinda smells like Antifreeze.
Window keeps fogging up
masopicman
I would agree with the heater core theory if you smell antifreeze. The ranger/bii bodys use a sealer in the drip rail that tends to get brittle and crack thus causing a leak into the cab giving you the wet carpet. Mine would drip down from the top of the windshield down onto the steering column.
Trigger_2001
offroadohio
Leaks
When iu first got my BII it was awsome defrost took 2 secs to get rid of iced winbdow sin mronming then they stayed clear then after a bit they always stayed foggy took me a bit but i finnally noticed the carpet was getting damp from a drainhole under the truck :)
4x4'ers Eat More Bush!
Re: Window keeps fogging up
Welcome Pueblo dude, I'm 20 mins from you in Florence. Anyways, I solved my problem by removing the doors and smashing out the windshield. Prolley be a little nipply in the winter.masopicman wrote:I recently bought an 84 Bronco 2! And the heat works well, yet side windows are always foggy, is this a common thing? or do I need to wash my windows?
masopicman
b2binbad wrote:Welcome Pueblo dude, I'm 20 mins from you in Florence. Anyways, I solved my problem by removing the doors and smashing out the windshield. Prolley be a little nipply in the winter.masopicman wrote:I recently bought an 84 Bronco 2! And the heat works well, yet side windows are always foggy, is this a common thing? or do I need to wash my windows?LOL
