lifting Q's, AGAIN
Posted: Fri Feb 11, 2005 9:06 pm
by NMB2
well i fixed the outter axle shaft so i have 4x4 again..i installed the 2" Add-A-Leafs and i actually got 4" of lift. was i supposed to take some leafs out or something
i also installed the coils and tried to see if 3.125* camber bushings would correct it but they wont....ive seen these brackets for sell before for like $40-$60...i have $50 if anyone has some laying around or can track me down a used set...help would be much appreciated...the sooner the lift works the sooner i can come out and play with ya'll
Posted: Sat Feb 12, 2005 5:07 am
by Phillippi
Are you talking about the adjustment bushings (metal) to get correct alignment? If so I have some that I bought and used with my duff 3" lift. Let me if thats what you need.
Posted: Sat Feb 12, 2005 1:54 pm
by NMB2
they are bushings that sit between the knuckle and upper ball joint to change its angle. from what i understand the most change is 3.125* and that wont correct 4" of lift. is what you have different or what? the brackets im talking about are the pivot drop brackets. lemme know
Posted: Sat Feb 12, 2005 5:57 pm
by Phillippi
Well the bushings I do have. I am not sure on the degree right off the top of my head, but I will look for it tomorrow during the sunlight.
Posted: Thu Feb 24, 2005 2:00 am
by no v8? why drive?
you cannot exceed 2" of lift without using drop brackets. The degree of adjustment needed at the knuckle to make up for a 4" lift is around 6 degree is which no one makes. you have to use drop brackets or drive around on the outside of your tires.....
