I really need some help with spark system
BroncoIIboy
So i bought this cool 1987 broncoii 5 speed 4x4 and the guy i had bought it from said it just needed a new fueling system so i replaced everything from the back to the front. Then all looked well so i tried to turn it over and it didn't want to so i got my dad to spray starting fluid in there and still nothing. He said its most likely the spark system which is weird because it turned over when we first got it with 2 broken spark plugs bad oil and it had been sittin for 20 years. So i looked at all the wiring and stuff but i have yet to actually test anything with our odometer. I replaced the distributor cap the rotor and plugs.Please contact me at Taylorgodley1121@Yahoo.com or 928 374 2116
WheelieWanda
Re: I really need some help with spark system
Hey man, sounds like you've put in some serious work on that Bronco II already! Since you've replaced the fueling system and the spark plugs, it's probably a good idea to check the ignition system next. If it's still not starting, it might be worth testing the ignition coil, spark plug wires, and ignition control module. Also, don't forget to check the battery and starter too. Keep troubleshooting step by step and you'll get that beast running smoothly in no time. Good luck with it, and feel free to hit me up if you need more advice.
