exhaust powered jack!
Wicked Bronco II
look at this accident prone masterpiece... actually i dont know if its that worthless but it caught my eye.... http://www.karajan.com/barter/barter23.htm
I believe you understand what you think I said but im not sure you realize what you heard is not what I meant....?
Heh......
I blew up a rubber raft once with exhuast...... Come to think of it, I think we gave up
Considering your tires easily hold the weight of your vehicle with only 5 psi, I believe these would easily lift a vehicle as your engine compression is around 150 psi. Of course I think it would be a little more pleasant to use on-board air.
