88 Bronco II Flywheel
Posted: Tue May 02, 2017 11:27 am
by skag1011
Got an 88 Bronco II, auto trans, 4WD. Having problems with the flywheel breaking. The last one didnt last a year. Any recommendations on where to buy a good quality flywheel? Also, I have found them with 138 teeth and 141 teeth. Which should I use? Any help is greatly appreciated.
Bill
Re: 88 Bronco II Flywheel
Posted: Wed May 03, 2017 7:32 pm
I am not sure which one you need. Where are the flex plates breaking at the center or on the outside edge. There are several reasons flywheels break. My Expierence is with breaking or cracking at the crankshaft bolts then it could be un balanced converter, A worn bushing in the front of the trans can cause converter wobble. Breaking near the starter ring is usually a sign of a mis aligned starter.
