2wd to 4wd conversion '89 Bronco ii
digdugtug
Postby digdugtug » Sat May 28, 2016 6:53 pm
Bronco ii '89 2wd automatic with A4LD
Swapped front axle with '92 explorer 4wd - no issues here
4WD harness and shift control module out of a '91 Explorer
Bronco ii harness has different wires and pin locations than '91 explorer 4wd harness
I've trimmed the connector so they will mate together but need a wiring diagram and/or pin out to swap wires with one of the plugs
Any help would be appreciated.
Users browsing this forum: Google [Bot] and 1 guest
