Clutch bleed
Clutch bleed
Hey everyone I have a 84 bronco2 I recently replaced the flywheel on but now I can't seem to find the bleeder valve for my clutch slave cylinder I have looked in the only places I think it could be (slave cylinder,an master)
Using Tapatalk
Re: Clutch bleed
If its the FM146 transmission, the bleeder screw is on the slave right above the hose connection. I may be wrong but the bleeder should be on the slave on most every setup.valm35 wrote:Hey everyone I have a 84 bronco2 I recently replaced the flywheel on but now I can't seem to find the bleeder valve for my clutch slave cylinder I have looked in the only places I think it could be (slave cylinder,an master)
kirkland2887
Re: Clutch bleed
Is there a little allen screw on the end
this is what my slave cylinder looks like
