Brake Line Leak
1990Bronc0II
Brake Line Leak
Post by 1990Bronc0II »
I have a 1990 B2 and it appears that i have a front passenger brake line leak. does anyone know how hard it is to replace the lines and what kind of tools i'll need. I am a novice mechanic and any help is appreciated. thanks!
Mud Addict
Re: Brake Line Leak
Post by Mud Addict »
Is easy to replace the line, but you will need to bleed the system build of all air after swapping the brake line. As for wrench sizes, the fitting at the caliper is (I think) 14 or 15mm. At frame end of line should be 7/16, but use a line wrench NOT a regular open ended wrench.
