88 bronco 2 engine ticking question????
Posted: Tue Mar 06, 2012 10:36 pm
by 1988bronco2
so i have an 88 b2 and when i start it up it ticks but then like 10 seconds after it stops. now when i get going it starts ticking slowly for like 10 minutes then stops but like 10 minutes later it comes back ticking like crazy and it ticks with the motor... whats goin on is it lifter tap or what??? i have been told its my exhaust rattling and or my water pump. please give me some suggestions!!! your help is greatly appreciated!
Re: 88 bronco 2 engine ticking question????
Posted: Wed Mar 07, 2012 12:52 pm
Your tick tick tick is indeed the Lifters or "Tappets". That is probably the most famous thing a 2.9 is known for. Poor clearances in the cam bearings cause a significant oil pressure drop before the lifters get their oil.
There is NO known cure for this other than replacing the cam and cam bearings. If you go that deep into an engine you better just rebuild it! One more thing a 2.9 is famous for is cracking heads. Do NOT let your engine overheat even slightly. If the motor overheats it will crack a head..
:cool: :cool:
Posted: Wed Mar 07, 2012 8:03 pm
by drofman
tek, where you been? good you're still around.
Posted: Thu Mar 08, 2012 8:05 am
drofman wrote: tek, where you been? good you're still around.
Hey there Drofman. I been fighting some significant medical problems. I have spent 99.9 % of my time inside recouping from a "Injured" neck and back. Believe me it has not been fun.
I been getting outside once in a while lately and will be back in the shop in about a month. Meanwhile I been watching and lurking about. So everyone better be careful cause I am back in town!!
