rear axel
feksrocks
rear axel
Post by feksrocks »
hi im new here and i recently bought a b2 and i live in ut a couple of hrs from moab i was in the junkyard last week and i spoted a b2 and the rear tag read 4ls10 or 4sl10 not 4l10 my b2 has an open 345 i read somewhere that the 4ls10 is limited slip but some sort of spring clutch or something would that b a good swap for my b2 and if so how difficult is that to do
Re: rear axel
If you are looking to swap out the entire axle, its not hard at all. Just replace. If you are looking to setup a LS carrier in our current axle, then you have to set up it correctly which is more of a specialty.
Where in UT are you? I am in Utah County.
