Page 1 of 2
loud rearend noise
Posted: Thu Jan 26, 2012 9:32 am
by 4d4life
have a 88 brono ii everytime turn right, a hard right, at about 20mph theres a pop in the rear end. it usually pops about 3 times. any ideas?
Re: loud rearend noise
Posted: Thu Jan 26, 2012 5:07 pm
by drofman
is it only on right turns or does it do it on left turns also. a locker rearend will do this but will do it on right and left turns. get in a big lot and make a couple of circles both right and left and see if it does both ways.
Posted: Thu Jan 26, 2012 5:37 pm
by 4d4life
only does it on right turns
Posted: Fri Jan 27, 2012 5:20 pm
by drofman
sound like it's time to tear down and inspect the rear end
Posted: Sat Jan 28, 2012 8:03 am
by drofman
Are you sure it's coming from the rear end and not the front end?
Posted: Sat Jan 28, 2012 2:24 pm
by 4d4life
im pretty possative its in the rear end. it only does it som of the time. is there any chance it could be rocks poping out from under the tires?
Posted: Sun Jan 29, 2012 2:21 pm
by 4d4life
yes the popping is comin from the rear end
Posted: Sun Jan 29, 2012 4:12 pm
by Icepicker
Have you pulled off the wheel and inspected your brakes, may be locking up, perhaps pull off the hub and pull the axle, (don't forget the C-clip) inspect the bearings. A worn spider gear or pinion will also factor into the problem.
Posted: Mon Jan 30, 2012 6:29 am
by 4d4life
problem solved just changed the fluid and it went away hopefully it woncome back
Posted: Mon Jan 30, 2012 9:55 am
by jefe
What fluid did you change?
Posted: Mon Jan 30, 2012 3:59 pm
by 4d4life
rear diff. put in valvoline 80w90. is this a good gear oil or what do yall recomand what weight?
Posted: Mon Jan 30, 2012 5:03 pm
by 4d4life
also just another thought if someone could help me out. i think my fuel gauge is goin out or the sending unit is. according to the odometer and the fuel gauge im only getting about 176 miles per tank. about how many miles per tank do ya'll get?
Posted: Mon Jan 30, 2012 9:08 pm
by jefe
4d4life wrote:rear diff. put in valvoline 80w90. is this a good gear oil or what do yall recomand what weight?
ok.....cause I think I'm having this same problem on this BII I picked up. I've been replacing fluid and gaskets in the engine so I need to add this to my list of things to do before I get her back on the road...
Thanks for the tip....and not sure on the gas mileage. BII has been parked for a while now.
Posted: Tue Jan 31, 2012 4:45 am
by 4d4life
yea when changed the fluid it was a dark dark brown with some sludge in it
Posted: Tue Jan 31, 2012 8:46 am
by jefe
I'm sure mine will be too considering the things I've seen so far...
