86 Bronco 2 Clutch issues
Posted: Sun Dec 25, 2011 5:28 pm
by danboy282
I just bought an 86 Bronco 2 eddie bauer 4x4, and the guy i bought it from put a new clutch in it said he drove it for a little while and now the clutch won't engage (stuck in or out of gear). I believe it to be just a matter of bleeding the system, but I am not sure exactly on the procedure. Is the salve cylinder on the firewall, or is it one of those concentric slave cylinders that mount over the input shaft in the bell housing? Or does it have both?
Another thing, the guys dad (previous legal owner) told me his kid(driver) may have used power steering fluid instead of DOT 3 brake fluid. Obviously, I will need to flush the system thoroughly, but will it affect the slave cylinder or tranny in anyway.
Thanks for helping out a F.N.G.
Re: 86 Bronco 2 Clutch issues
Posted: Sun Dec 25, 2011 10:28 pm
by Mud Addict
I use a hand operate vaccum/bleeder to do mine. The bleeder screw sticks out of the bell housing just above where the line goes in.
Posted: Mon Dec 26, 2011 10:08 am
by danboy282
do you think power steering fluid would mess with the slave cylinder at all?
Posted: Mon Dec 26, 2011 1:09 pm
About 5 years ago I went to fix an old mans brakes because he did the same basic thing. He put Power steering fluid in his master cylinder instead of brake fluid. I pulled the master
Cylinder put a rebuild kit in it and flushed the rest of the crap out. The total time the system had the oil in it was maybe 48 hrs and you could see the rubber components had started to swell.
See in as this is just the clutch try to flush out the crap and replace with fluid and if you have any leaks replace the components.
Posted: Mon Dec 26, 2011 3:15 pm
by danboy282
Thanks for the info every1
