I need a little help with remembering how the wiring harness is run from the dash to the center consel on my 86 Bronco II. The harness drops down to a plastic clip on the trans tunnel. Then it has two etal platesonnected on it ithat get screwed to the ?. Then there is another plastice clip after the gear shilt lever. Does the harnes run on the passenger side or the drivers side? Does it screw to the trans tunnel? I can't find any screw holes and I cant' remember. Anyone know or have a picture?
Thank you
DACriss
Need a little help
Need a little help
- Attachments
- IMG_1498a.jpg (25.94 KiB) Viewed 2856 times
