fluids
Posted: Wed Aug 31, 2011 8:47 pm
by kaytor692
just wanted to no what oils its run in my diffs, tranny, transfer case? 75w-90 80w-90 what do they call for ?
Re: fluids
Posted: Wed Aug 31, 2011 8:58 pm
by Mud Addict
Diff 80-90, T-case ATF, trans ATF manual and auto
Re: fluids
Posted: Thu Sep 01, 2011 3:06 am
by Ranger Dave
depends on what trans
Re: fluids
Posted: Fri Sep 02, 2011 6:06 pm
by kaytor692
ya its a 5spd probly should have said that
Re: fluids
Posted: Fri Sep 02, 2011 6:54 pm
by Ranger Dave
gonna get crap for this BUT,look in a hayns manual chapter 1 page 2 and tell me what is says for lubricants for the manual trannys. both my 146ers have over 200,000mi with 80/90w. and dont make a noise. the M5's ues the ATF. the M5's have a oil slinger(some call it a oil pump, its not) thats why its need the thinner oil. the t-cases have a pump in um,they need the atf also
the pump in the tcase
Re: fluids
Posted: Fri Sep 02, 2011 7:29 pm
by Mudhog1977
Lookin at haynes manual... 83 - 87 sae 80w... 88 on, mitsu- sae 80w, mazda- mercon... Transfer case- 83 -87 dextron1, 88 on - mercon... Hope this helps a haynes manual is a good investment well worth the 20 bucks or so u pay for it I like haynes better than chiltons personally I cant remember how to tell the transmissions apart I think u can tell by the type of pan it has I think one is aluminum and one isn't
Re: fluids
Posted: Fri Sep 02, 2011 7:38 pm
by Mudhog1977
83- 87 dexron...touch screen sucks sometimes lol my 89 b2 has 397,482 original miles and it started makin a lil noise at about 385,000 I finally wore the body out and had to retire it to a parts donor the only prob I had was I lost 4th gear right b4 I parked it but I ran it pretty hard
Re: fluids
Posted: Tue Sep 06, 2011 8:53 pm
by kaytor692
i think its a A4LD i no the transfer case runs atf but the tranny has a leak in the top were the shift comes out i belevie the shifter has some slop in it well its in gear. the leak looks like its 80w-90 to me due to the smell and that the oil is green. are the tranny and T-case supose to run the same oil or are they different in some models?
Re: fluids
Posted: Wed Sep 07, 2011 12:41 pm
by Mudhog1977
Cant be a4ld thats an auto
Re: fluids
Posted: Wed Sep 07, 2011 9:08 pm
by kaytor692
hmmm soooo i should run atf in it then ?
Re: fluids
Posted: Thu Sep 08, 2011 3:13 am
by Ranger Dave
kaytor692 wrote:hmmm soooo i should run atf in it then ?
NO!!!!
Re: fluids
Posted: Thu Sep 08, 2011 4:48 am
by Mudhog1977
A4ld is an automatic transmission not a manual transmission 5 speed
Re: fluids
Posted: Thu Sep 08, 2011 8:20 pm
by kaytor692
80w-90 it is then lol
