Bronco 2 Start and Stall
Posted: Tue Aug 30, 2011 4:00 pm
by tim1
my bronco jus got running an when i start it for the first time everyday it will stall once or twice and i dont knw y.any help would be appreciated.
Re: Bronco 2 Start and Stall
Posted: Tue Aug 30, 2011 10:18 pm
by Jorley
what year is it and which engine?
Posted: Thu Sep 01, 2011 4:25 am
by fireproof710
Head on down to your nearest autozone and pick up a code reader. If you don't already have one, you can pick up a cheapie for around 30 bucks. It doesn't have a screen, you have to count the blinks of an LED light, but it comes with a code book that will direct you to the problem. Obviously there could be a whole range of things causing it to stall. I had a similar problem, and was replacing things right and left trying to diagnose the problem. Then I got the code reader and it directed me to a faulty Manifold Absolute Pressure (MAP) sensor that went bad, sending false readings to the computer, and sure enough that was it.
So....
1) Pick up a code reader
2) (as Jorley said) Which year/engine is it?
3) Can you give us any more symptoms other than the stalling? How does it run after it gets going for example?
Posted: Fri Sep 02, 2011 8:02 pm
by tim1
1987. 2.9, 6 cylinder. it usally stalls just once then runs decent but runs bout 1500-2100 rpms.
Posted: Sun Sep 18, 2011 10:03 am
by tim1
wht code reader should i get?
Posted: Mon Sep 19, 2011 10:12 am
by moogvo
Sounds like the IAC valve to me. Maybe dirty throttle plates too. How does it run once it is warmed up? Does it lose power driving down the road?
Posted: Mon Sep 19, 2011 2:26 pm
by tim1
ya its runs ok when its on the road sumtimes but other times it will just shut off while im driving.
