sounds like an automatic weapon
my 88 bronco2 sounds like an automatic weapon when i give it gas, if i let off the gas it goes away but returns when ishift and give it gas again anyone had this problem?
Re: sounds like an automatic weapon
maybe an exhause leak or loose spark plug? the right side exhause manifold like to leak.
exhaust.
Sounds like the rig has been previously owned by an terrorist and you have the 9MM Full Auto version. Take it to your local gunsmith and have him re-chamber to 7.62.
well the guy wasnt a terrorist but he is a pain in ass, not really well maybe!! im wondering if it mite be somthing with the ignition
the sound is like a backfire but it repeats until i let off the gas then i have to down shift. then when i get to a certain amount of gas then it does it again. it seems to do it when i give it more gas not at lower amounts of gas
Well, i took the valve cover off, and i discovered the problem, one of rocker arms was almost off the valve spring. i put it back to its right spot started it up it sounded 100% better, and no submachine gun sound lol thanks for the replies, there are some other issues to deal with but that one was the biggest
wow, how did that happen? did you work on it lately? thanks for the reply. many don't.
no, i bought it some time ago from a buddy of mine who bought it from a small dealer. he said it had a tick to it, i wasnt scared of that because ive had 4 of these in the past 15 years, and i know that they can have a loud valve train, the valve covers were leaking so i figured i could adjust them down or at least c what the deal was. i did notice a vacume plug in the oil return area if that is what caused it i really dont know, but its alot better now so its on to tune up stuff.
