transmission is half ingadged in drive in every gear
Posted: Mon Jun 13, 2011 10:23 am
by little grey ford
im pretty new to the bronco 2 and only know a little about them.just recenly my a4ld trani has become half engaged in drive in every gear after a night of playing around. park is half engaged in drive reverse is half engaged in drive and neutral is also drive.idk which way to go with this so any tips or advice would be great. little grey ford:)
Re: transmission is half ingadged in drive in every gear
Posted: Mon Jun 13, 2011 8:44 pm
by didittwice
well you could try changing the fluid or a vac.hose came of the modulater on the trans.
Mine is sitting on the ground and will be going by by.
Posted: Tue Jun 14, 2011 3:02 am
by Ranger Dave
bent some linkage
Posted: Tue Jun 14, 2011 3:00 pm
by little grey ford
ive checked everything outside the tranni and changed the fluid and also replaced modulater valve and still doing it. im afraid its internal and dont really know much about the inside. is it worth it to rebuild the A4LD or switch to somthing else?????
Posted: Tue Jun 14, 2011 3:38 pm
by Ranger Dave
get rid of it, chang it over to a 5spd
Posted: Tue Jun 14, 2011 8:25 pm
by didittwice
Image Here is mine it is free to how every wants it. Yes go 5 speed
Posted: Tue Jun 14, 2011 8:36 pm
by Mudhog1977
Maybe the linkage adjuster bolt came loose
