New Member, Need Some 302 Tranny Info
Posted: Tue Nov 16, 2004 8:15 pm
by Kris
what i am wanting to do is throw a carb. 302 in my truck, i cant handle these 2.8's, ive went through one allready, and the second is leaking oil, and now burning it(allthough im sure its just burning because of the valce seals)
swapping in a 302, is there any standard transmission i can run that will bolt up to the stock 1350 transfer case? i wont run any other case, because of the doubler. or am i better going with a c5? and if i go with a c5, what do i get the bellhousing from so that it will bolt to the 302?
Thanks
Posted: Tue Nov 16, 2004 10:12 pm
by broncoo
you already have the doubler?
if you wan to keep it then get a conversion bellhousing but i can't say how long the tk5/4 will last with v8 power
other than that i can't say cuz i run c6/203/205
Posted: Tue Nov 16, 2004 11:44 pm
by Kris
i was under the impression i can not run the tk4 behind a 302, and i need all the driveshaft legnth i can get, if i even go through with this swap.
Posted: Wed Nov 17, 2004 12:50 am
by FatMan
why not go with the 4.0 conversion i think it will fit your tranny. just a thought. it's no V8 but it's better than a 2.8.
Posted: Wed Nov 17, 2004 7:53 am
the c5 will work if you swap some internals from a c4 into it. the 4.0L will be a bolt in applcation.
Posted: Wed Nov 17, 2004 3:29 pm
by b2binbad
i wont run any other case, because of the doubler. ..
Is that a 1350 doubler, if so, how's it working for you and who built it?
Posted: Wed Nov 17, 2004 3:36 pm
by Kris
its being built by TLE 4XFAB up here in canada, not quite done yet.
the 4l would be a swap in, but there is so much wiring it is rediculious.
Posted: Wed Nov 17, 2004 3:49 pm
by b2binbad
How much??
Posted: Wed Nov 17, 2004 5:33 pm
by Kris
1200 canadian
Posted: Wed Nov 17, 2004 8:38 pm
by b2binbad
Here's another place that makes 'em for a little cheaper.
http://www.tandmoffroadproducts.com/
Posted: Wed Nov 17, 2004 11:13 pm
by Kris
im up in canada, freight on that plus boarder fees will be a lot more than what im paying
Posted: Thu Nov 18, 2004 4:36 pm
by wilber
run the c5 with a c4 bell, or a c4 with a c5 tailshaft and housing for the tcase
