Gears?
Posted: Tue May 24, 2011 6:29 pm
by Mudhog1977
Does any know if it will hurt anything if I run a 8.8 with 4:11 gears on the back with the dana 28 with 4:10 gears on the front? I know your not supposed to run different gear ratios but I was unsure being that they are so close, not like im runnin 4:10's with 3:73's any feedback would be helpful I cant afford to buy both diffs at the same time thanx
Re: Gears?
Posted: Tue May 24, 2011 6:38 pm
by drofman
they used to do this in the old days
Re: Gears?
Posted: Wed May 25, 2011 9:36 pm
by Phillippi
I cant imagine that, that small of a difference will make much of a difference. Even with the front locked I would run it until it exploads (like mine did) then upgrade.
Re: Gears?
Posted: Thu May 26, 2011 4:29 pm
by Ranger Dave
chevy did that for years.
Re: Gears?
Posted: Fri May 27, 2011 1:41 pm
by Mudhog1977
Thanks for the help yall
Re: Gears?
Posted: Fri May 27, 2011 6:00 pm
by drofman
Ford did too. Wanted the front end to pull the rear end, Worked good in sand and snow.
Re: Gears?
Posted: Sat May 28, 2011 2:33 pm
the ratios don't have to perfect...I think you are allowed 2% if I remember correctly.
