89 b2 wit a 302 question
Posted: Thu Apr 28, 2011 5:06 pm
by ---muddigger---
yo i got a 89 wit a 302 in it
runs strong as hell n is pushin 400hp beleive it or not
but when i go to shut it off i turn the key to off n it still wants to run. it kinda putters llike its gunna conk then it shuts off. any tips?
thx
Re: 89 b2 wit a 302 question
Posted: Thu Apr 28, 2011 5:31 pm
by Ranger Dave
retard the timming a little,or turn the idle down. whats the specs on the motor
Posted: Thu Apr 28, 2011 5:34 pm
by drofman
beat me to it Dave
Posted: Thu Apr 28, 2011 6:08 pm
by ---muddigger---
well i jus got the beast. its a 4 barrel bored out 302 with: 650 eb carb, long tube headers, no cats, flomaster dual 40s, dual pushers, aod trans, the entire engine is rebuilt with aftermarket cams, pistons, rods , n manifold. theres even more stuff done to it that im forgetin. anyway its lifted 7" w/33 but im goin t0 35s
Posted: Fri Apr 29, 2011 7:56 am
Try running some high octane gas. If it's a built engine, then it might have a high compression ratio, causing it to detonate once the ignition is turned off.
Posted: Fri Apr 29, 2011 10:47 pm
by ---muddigger---
yeah i gotta try it n im gunna adjust the carb too thx
Posted: Sat Apr 30, 2011 11:38 am
by justinC
you should try retarding the timing because if its to far advanced it will cause excess heat in the cylinder thus allowing the gas to detonate with out spark. A couple degrees will make a difference.
Posted: Sat Apr 30, 2011 1:06 pm
by Ranger Dave
justinC wrote:you should try retarding the timing because if its to far advanced it will cause excess heat in the cylinder thus allowing the gas to detonate with out spark. A couple degrees will make a difference.
Ranger Dave wrote:retard the timming a little,or turn the idle down.
didnt i say that
Posted: Sat Apr 30, 2011 3:23 pm
by ---muddigger---
yeah thx guys. problem solved. good as new
Posted: Sun May 01, 2011 4:40 am
by Ranger Dave
---muddigger--- wrote:yeah thx guys. problem solved. good as new
soooo,you gonna tell us or want, we told you what to try
Posted: Sun May 01, 2011 10:02 am
by ---muddigger---
the throttle was stickin a lil so i made a braket n put a spring on it to make a throttle return n its perfect now
