B2 wont turn over
B2 wont turn over
Re: B2 wont turn over
pull the plugs and turn it over with the starter. guess ya shouldnt of gone so fast through water
Your engine is, or was Hydrolocked.
You sucked water into the engine and water don't compress! Pistons stop and let the carnage begin.
It makes bad things happen.
The things it does is bend connecting rods, bend valves and generally screws up your engine. A quick trip to the auto parts store is not going to help.
Pull the motor and replace it!
even with a bent rod it will still run/turn over. theres most likely water still in one of the cyls. the 3.0 that WAS in my 95 ranger what hydroed so bad it broke 2 rods,poked a hole in each side of the block and that still ran,not good but still ran
I had a Pontiac 4 cylinder throw a rod and all we did was stuff a rag in the hole and some tape and we drove that bugger all the way home. about 25 miles.
- Mud Addict
1st time I hydro'd a engine bent the rod to the point of being unable to turn engine either direction.
