87 BII question - injectors - fuel pressure - and more
Posted: Mon Feb 07, 2011 8:47 am
Hey all.....I'm in the process of tearing into the engine on my 87 BII 2.9L to fix some leaking oil issues, starting with the valve covers.
Since I am taking it all apart, I figured I might as well check into everything else, so I have a couple of questions.
Thanks for any help.
- - I want to take the fuel rail off to inspect the injectors and so I can replace the gaskets on the lower mani and I noticed the manual says I need to release the pressure from the fuel system using a hand pump. Since I don't have a hand pump, I was hoping there was another way to do this so I don't spill fuel all over the place. Anyone know?
- Should I go ahead and replace the fuel injectors since I have the engine apart? I've only had the BII for about 8 months and have no idea if this was done before.
- When I drained the coolant, I noticed some oil in the coolant but only when it first started draining out, then no more oil while the rest of the radiator drained. Is this a big deal?
