Fuel Line Trouble
Fuel Line Trouble
i cant seem to get my fuel lines off of the fuel pump.i loosened the tab but i cant get it off. any help plz.
Milton deal
Re: Fuel Line Trouble
There's a clip attaching them so just take it out with some pliers or I just used my fingers.....it helps if u take the fuel line of the rail so u can twist it around to c wat ur doin then just jiggle it off but u should take the clip out and not just loosen it
also if you use some of the ford plastic fuel clips to put the hose back on like if you break one the new plastic clips are way easier if you grind them down a little because I got stock replacement ones and weren't even close but after sanding them down they fit like a glove
