Bad clutch?
Posted: Tue Jan 11, 2011 11:00 pm
by tmg1018
My 85 B2 is shifting strange. It's new to me so not sure if it has always done this but hope you all can help me figure this out.
The clutch peddle does not feel like it has too much play or spongy at all. When I shift (no matter what gear) I need to let the peddle almost completely out and give it extra gas. No noise or vibration out of the ordinary. The guy I bought it from said he thought the clutch just needed adjusted but in researching I have discovered I have a hydraulic clutch that can't be adjusted? I have found very little on any of the boards to help me out with this.
Help!
Re: Bad clutch?
Posted: Wed Jan 12, 2011 9:46 am
by didittwice
If the clutch is not slipping it is not bad , it dose sound like it is worn down and will be going out.
dose that have the 2.8 or the 4 banger
Mine is 86 so i do not reserch any thing older.
Re: Bad clutch?
Posted: Wed Jan 12, 2011 11:16 am
by Ranger Dave
didittwice wrote:If the clutch is not slipping it is not bad , it dose sound like it is worn down and will be going out.
they never had a 4cly
Re: Bad clutch?
Posted: Wed Jan 12, 2011 7:28 pm
by tmg1018
Oh yeah definitely going bad, barely limped home tonight. Pedal is now very slow to come up after being pressed.
What is the cheapest route to fixing this you think? I'm a poor student. My dad can help me with the work but need to know about parts and such.
Thanks
Re: Bad clutch?
Posted: Wed Jan 12, 2011 7:43 pm
by didittwice
Well put a new one in if you want to do it right you will need to check the fly wheel you clutch kit will come with the pressure plate but you do need the new slave cyclinder (do not put the old one back you will have to pull it and replace it will leak) I will be up to you on the fly wheel???
The clutch kit and slave cyclinder will run about 200.00
Re: Bad clutch?
Posted: Wed Jan 12, 2011 7:46 pm
by didittwice
the best way to see go to autozone.com and put your info. in ..
Re: Bad clutch?
Posted: Fri Jan 14, 2011 6:40 pm
by broncofan
Not to sound stupid, but did you check your clutch master cylinder level. Make sure theres no leaks in it. do the easy things first
Re: Bad clutch?
Posted: Fri Jan 14, 2011 7:01 pm
by tmg1018
It does appear that I might have a slow leak from the reservoir. Hard to tell for sure as the engine compartment is real dirty everywhere! I am going to be cleaning it up tomorrow morning before I do any other work. I sprayed it all down with some good degreaser tonight and will let it set for a bit and then spray her down.
I have found a few other old hoses that look pretty tired so I will be swapping them out too. Got my garage all cleaned out today just in case I have to pull her in there to change out the clutch. To darn wet and cold to be doing outside for sure.
Re: Bad clutch?
Posted: Sat Jan 15, 2011 5:23 am
by Ranger Dave
tmg1018 wrote: Pedal is now very slow to come up after being pressed.
sounds like the slave cyl is hanging up. gotta pull the tranny
Re: Bad clutch?
Posted: Sat Jan 15, 2011 9:35 am
by tmg1018
Dang internal slave. I have heard about people with jeeps converting their internal slaves to externals. Any tech on how we can do that with our B2s?
Re: Bad clutch?
Posted: Mon Jan 17, 2011 6:12 pm
by bronco_ swimmer
I got my new clutch and flywheel at checker for about $170 i think. I had to pull mine last week. When you put it back in make sure you have extra hands there to get it in. Also before you do it leave it in gear (if you can) so that when you but the tranny back you can just rotate it and make it a ton easier. Goodluck..
Re: Bad clutch?
Posted: Tue Jan 18, 2011 7:14 am
by tmg1018
Thanks for the advice. I picked up a new clutch kit from criagslist for $50. Still can't believe I found that deal. Still looking for a decent priced flywheel someplace. I would like to just have mine resurfaced, hate to buy something new if I don't have to, but can't seem to find anywhere that can do it reasonably.
I can pick up a new clutch master cylinder for about $32 or so from a local auto parts shop, it's the dang slave that's going to kill me. Best price in town is still well more than $100 and online for around $60.
No way I'm goin to tear that tranny off and not replace the slave while I'm in there. I sure as heck don't want to get back in there in a few months to replace it if I don't.
I will probably be able to get started on it this weekend. I have some help coming over. I'm not sure how long it normally takes for that job but I figure I will at least double it since I have never done it and my help(dad) is slower than snot. Ha
