Why is there no fuel?
Ok, I have a new in tank fuel pump and it's pumping fuel. I'm not getting fuel to my throttle body though. Do y'all think it's the low pressure pump.
Re: Why is there no fuel?
I had a simular problem...My high pressure pump on the frame wasnt pumping right.I replaced the female power wire connectors on it and it started right up
...Hope this helps
Oh ok, I hope that will work. Thanks.
No problem
On a two pump system the in tank pump is the low pressure pump. So it sounds like your high pressure pump on the frame isn't working.luthier wrote:Ok, I have a new in tank fuel pump and it's pumping fuel. I'm not getting fuel to my throttle body though. Do y'all think it's the low pressure pump.
Bill
1990 BII, 4.0, (sold)
2005 F150 SCrew
'84 Ranger under construction
2005 F150 SCrew
What's up 04. I'm actually pretty sure I've got it figured out now. At first that's what I thought it was but I go to taking my fuel lines off and I've got fuel right up to my h/p filter and nothing past it so I'm thinking I've got it and hoping I don't have to buy a h/p pump.
