I am about to purchase a 90 model super clean great running Bronco II 2WD
I want to convert to 4WD
It does not have the dummy transfer case
I have a donor 84 Bronco II for transfer case
Suggestions please
I have read the 92-94 Exploder 4 x 4 front differential is direct bolt on, I plan to take the springs as well, would the trasfer case work or should I use the WB1350 from the 84, I am familiar with the need for matching gears in the front and rear and will likely change the rear to the explorer to. Any pointers advice appreciated.
90 Model 2wd Conversion
Re: 90 Model 2wd Conversion
your gonna need a tranny if your B2 doesnt have the dummy tcase. try to find a 1350/1354 manual tcase so ya dont have to mess with all the wiring
