After installing 2 inch lift....
My tires on my 88 b2 are tilting in slightly, will a canter/caster adjustment take care of this or will I need to do something else??
				red6x6stag
Re: After installing 2 inch lift....
just adjust ur tie rod for right now.
				RakerBill60
Are they tipping in on the top, or front? If they are on the front, then you can adjust your toe-in via your tie rods.
If they are tipped in at the top, then it is a camber adjustment.
Either way, it is best to have it done by a reputable shop to avoid any driveability or stability issues.
