brake light help?
beachbumtroy
brake light help?
1989 broncoll brake light and blinker was out so i replaced the 1157 bulb and i have blinkers now and running lights but no brake light on that side,what could it be i cleaned the socket and double checked the bulb but still no brake light on that side other side worx fine any leads appreciated thnx bb
RakerBill60
Re: brake light help?
Last time I ran into that problem, it was the turn signal switch on the steering column. Both brake and turn signal lights share the same circuit so they both don't come on at the same time.
Might be easiest to have a shop diagnose it to see if it is the problem or not.
Just a thought.
Just a thought.
beachbumtroy
it was the switch thnx will get new 1 at jy
