here goes
can you thak the axel tubes off a low pinion D44 and turn the center section around to make a high pinion.Just tring to think of a way to get less of a driveshaft angle
prolly a stupid ??? but
Bone stock'88 Bronco II stuff, actually it is the stuff that came from the factory on the BII, in 1988, just a mere 301,000miles ago.
I did grind a lot of material out of the face of the driveshaft where the Tcase joint would/could hit. Other than just limiting the amount of drop on the left side it works pretty good.
92 XJ-wifes toy
92 XJ-wifes toy
