hey dudes,
i am new to this website, i have a 1990 bronco2 that is currently in washington. it may be headed down here to temple texas for a daily driver/project. it is 4wheel drive with a five speed tranny. the tranny may be shot (makes noise in every gear but 4th) any info on rebuilding, or where i can find a used one would be great. thanks!!
your pocket bearing is bad in the input shaft. in 4th input and main shaft are 1 to 1. the old TK trannys did this till they raised the lube level. more than likely you'll need an input and main shaft.
