Some one stole the gas out of my bronco. I didnt know it because my gauge doesnt work. I filled it up and parked it for a couple weeks outside then I drove it into the garage. I went to pull it out and it wouldnt start. I guess I ran the last of the gas out pulling it in the garage. I filled it up, wont start. If i spray carb cleaner in the intake it will start for a minute. Fuel pumps both work. and I bled the fuel system. Its an 87 2.9. Any other suggestions? Its not the inerta switch either.
THanks for any help I really need to get this thing running.
Some one stole my gas now wont start!
2001 Jeep XJ 6.5" Lift
2005 Crew Cab Z-71
1990 Jeep XJ 3'Lift
1987 BII Stock so far
wtf is a dikfer?
2005 Crew Cab Z-71
1990 Jeep XJ 3'Lift
wtf is a dikfer?
cscott9016
Re: Some one stole my gas now wont start!
If u know for sure it is a problem with the fuel system, I would first check fuses and then try the fuel pump relay.
