Mirrors
Mirrors
In case anyone was interested the breakaway mirrors will fit the same holes as the smaller black mirrors. Or at least the top will. You will need to drill for the bottom ones but it can be done.
1990 Bronco II, XLT, 5 speed
1970 F250 Camper Special
Re: Mirrors
Thats what I did with mine. For the bottom I just drilled a pilot hole then used some small self tapping screws. Makes sure what you use on the bottom is short otherwise you will mess up your windows.
Re: Mirrors
Thats what I would do if I didn't have to take the inside door panels off. I need to free-up one window and will put some sound dampner.90redb2 wrote:Thats what I did with mine. For the bottom I just drilled a pilot hole then used some small self tapping screws. Makes sure what you use on the bottom is short otherwise you will mess up your windows.
