oil leek
Posted: Tue Jun 01, 2010 3:04 pm
Would oil leek from a rear main seal for several days after shutting off the motor does'nt it return to the pan when you kill the motor to keep the pump primed ?
If it's from the rear main, it will be all inside the bell housing and might take a few days to all leak out.jaydbaker wrote:Would oil leek from a rear main seal for several days after shutting off the motor does'nt it return to the pan when you kill the motor to keep the pump primed ?
