87 bronco 2 Transmission
My bronco has a 2.9L V6 and it is a 4x4 when driveing it as it goes into third it will rev up like it is stuck in nutural. if i let off let it idol back down, and get back on the gas it shifts right into gear, and also it is slow to go into reverse
RakerBill60
Re: 87 bronco 2 Transmission
Service the tranny, get a new filter and fluid, and check it over good, sounds like either a sticky valve, or low fluid.
Low fluid can cause this, better get it checked out ASAP, or you will have a big boat anchor.
