Well, here's the story. I am in the middle of a 2" body lift on my 85 B2 so I can clear my new 31x10.50 treadwrights and ran into a little problem. I ordered new urethane body mounts but they did not come with the steel sleeve that goes through the middle of them. So now my bronco is another lawn ornament until I can get some sleeves. Can you order them or would I be better off trying fastenall or a hardware store.
Im thinking now I should have went with a suspension lift.
Problem with Body Lift
Re: Problem with Body Lift
LMC truck wants 20 bucks a piece for them. Thats not going to happen. What has everyone else used. Do I have the only bronco with a little bit of rust or what???
why dont you try getting some conduit from the electrical dept at the home depot and make your own sleeve, im not sure what the crush strength is but i bet it will work
