Okay, so the first is simple and dumb to ask, but where exactly on the fuse panel should I hook up the positive wire for the backlight on the new oil pressure gauge I just installed? The gauge works great, and thanks to this forum for saving me time, money and headaches by recommending the mechanical oil pressure gauge before replacing the oil pump...you guys are lifesavers.
The second question is also embarrassing, but I broke the knock sensor when trying to take it out mistaking it for the oil pressure sending unit (I know, I know
). Anyway, at the auto parts store the part for an 84 BII was unavailable but they could order one for the 85 - would there be any difference in the part since it's the same 2.8 engine? More importantly, if the truck is running the same without it right now and the wiring under the hood is already a bit shotty, should I really worry about replacing it at all?
Any help would be greatly appreciated...thanks!
