1. the rear end was swapped for a 96 explorer wit 4:10 gears put in but driveshaft does not match up with rear transfer case. what is most reccommended
2. its a hatch back but i wanna do a chop-top. any advice will be accepted
3.i want a total of 13 inches of lift its got a 3 inch body how can i add 10 inches? all major lift manufactures have either discontinued or out of stock.
im open to any and all advice so please shoot me some info
just gotta 1988 bronco II need some tech advice
cowboy_jbcc
Re: just gotta 1988 bronco II need some tech advice
hey man, if your going to lift it 13in... i would just rip out the drivetrain you have now... and get rid of it... go to the JY and grab a set of one tons and a motor. then build a ladder style lift and have leafpacks made for your lift...
these trucks are top heavy enough as it is. and if your thinking that choping the top is gonna fix that, its not... one tons will get you stronger and wider. wider the base, the better. and it will allow you to safely run larger style tires in order to accompany a lift of that size.
doing that will eliminate your first question all together.
and heres a link for your choptop.
http://www.broncoiicorral.com/choptop.htm
have fun, kolton
have fun, kolton
Shake and Bake
