Fuel problems HELP
Fuel problems HELP
Ok, I have an '88 Bronco II. It has been a good truck for the most part but in the last year and a half I have replaced the fuel injectors (one mounth ago), both fuel pumps(year 1/2 ago), the computer modual(6 mounths ago), fuel regulator and fuel filter(a year ago). Well we were in are process of moving from Nabraska to Arkansas when it started to run really rich and chug then it just died and I have not been able to start the Bronco since. The computer is throwing two codes 67 neutral drive sensor open and 87 primary fuel pump circuit failure. DOES ANY ONE HAVE ANY IDEA ON WHERE TO START AND WHAT COULD BE THE PROBLEM?
Re: Fuel problems HELP
fuel pump fuse or relay, also make sure everyting is grounded well. The neutral saftey switch prevents you from starting in drive or reverse. Just my two cents. -Jeff
'73 vw bug
'70 vw camper van
'98 jeep tj
2010 ranger
'56 international s110
'73 vw bug
'70 vw camper van
'98 jeep tj
2010 ranger
I cant seem to find diagram for witch relay go's where there are three under the hood but witch one is it? thanks
