Went through water stalled out help!!
Posted: Tue Feb 16, 2010 7:24 am
by aarnwts
86 Ford Bronco II 2.9L EFI
the water wasnt too deep up to the bottom of my door. I went through the large puddle twice with no problems. My gas is good and pressurized. Fuel pumps turn on Battery is good starter isnt turning the motor over. Its clicks but no turn not sure if im getting a spark yet. My intake tube was wet on the inside but mostly dry my intake filter was soaked though. My buddies and I Imediatly got out and pushed it out of the water. Can you flood your starter. Not sure where to start. Gotta get her all the way home first. I havnt checked my oil but like I said the intake tube was wet on the inside but mostly dry. any advice on to get this thing runnin would hate to throw it away. Guess a new motor is the worst case scenario. PLease Help!!
Re: Went through water stalled out help!!
Posted: Tue Feb 16, 2010 4:08 pm
by Ranger Dave
if its a std put it in gear and push it and see if it will turn over, pull all the spark plugs out first
Posted: Tue Feb 16, 2010 6:30 pm
by aarnwts
sorry ranger dave std? its an automatic. Im stock and it went to the bottom of my doors. not in the truck tho. Can you flood a starter out?
Posted: Wed Feb 17, 2010 12:56 am
by Ranger Dave
well ya
Posted: Wed Feb 17, 2010 8:28 am
by aarnwts
A new motor is only 650 bucks I already have a rebuilt tranny so I would virtually have a new truck. Water did get in my motor the oil level went up about 1 quart so that what I have in my motor.
Posted: Wed Feb 17, 2010 6:30 pm
Hydro-locked!!!
Ouch. Sounds like what happened is when you air filter got saturated with water your engine sucked it in and as we all know water does not compress. When this happens it usually does something ugly inside the engine like bend rods and hammer cranks.
Pull all your spark plugs then drain and refill the engine with clean oil. Try to turn the engine with the plugs out. You might get lucky. if it turns over dry everything install fresh plugs and go for it. If it doesn't turn over, Play a tune of Taps on your bugle and stuff another engine in.
Posted: Wed Feb 17, 2010 8:31 pm
by aarnwts
I like how you said that haha Im preparring for it now. The real question is should I re-build that one or go for a used one from a recycler?
Posted: Thu Feb 18, 2010 5:49 pm
To Fix. Or. Replace or not. it all depends on what you are seeking and what your budget can handle.
Happy with the fuel mileage and current power then just stuff another 2.9 in. Want more power stuff a 4.0 in. If ya got to have lots of power then go V8. It's all up to you.
Posted: Thu Feb 18, 2010 6:24 pm
by aarnwts
will it still pass smog? for CA
Posted: Fri Feb 19, 2010 1:10 am
by Ranger Dave
why not see if it still runs first
Posted: Fri Feb 19, 2010 11:34 am
by aarnwts
My motor will not turn over at all. Ive tried with the starter and ive tried by turning the camshaft pully with a socket. It is frozen so to speak.
Posted: Fri Feb 19, 2010 2:45 pm
by aarnwts
Gonna order a new motor from oregon! Problem solved
Posted: Fri Feb 19, 2010 3:03 pm
by Ranger Dave
did you learn anything from doing that
Posted: Fri Feb 19, 2010 5:23 pm
by aarnwts
yup stay the hell outta the water! 700 bucks isnt worth seeing whats on the other side
Posted: Tue Feb 23, 2010 8:10 pm
Case Closed!!
