voltage draw in lighting sys
Posted: Sun Dec 27, 2009 9:44 am
by drofman
i have a 88 bronco 2 that kills the battery after 3 days. i've norrowed it down to the lighting system (unhooked the fuse link) and it's between the fuse link and the light swt. does anyone know where it might chaf here before i start ripping the wire loom apart? it must be barely rubbing. thanks
Re: voltage draw in lighting sys
Posted: Sun Dec 27, 2009 10:22 am
by drofman
oh, and i've deleted the door lock curcuit on that curcuit, replaced the battery, unhooked the alt and alarm sys, replaced the muti-function swt (still can get it from napa) still have draw
Posted: Sun Jan 17, 2010 3:12 pm
by drofman
Just to let someone know if they have the same problem I found my draw. After cutting wires and following the curciut (thank gosh I kept the wiring dia. from the last Ford dealer I worked for) I found that the lumber support curcuit fried my fuse block. Looked good from the front and didn't pop the fuse link but was enough to kill the battery. Glad I bought that $50 BII sitting in my back yard. By the way, I have 317,000 on this ride and the heads have never been off and the sqeeze is still good. Keep on changing that oil
