bushing questions?
bushing questions?
what bushings do y'all run in the front with the D44 and duff coils?
I was wondering if I should mix and match, go all rubber, or all poly?
My axle came with duff poly bushings, so that's what I run. Rubber would flex better, but short life doesn't make it worth it. Definately go poly. Any of the big name companies should be fine. Who you buy from mostly depends what color you want.
I kinda figured that the rubber would flex better, but like you said I don't want to replace them to often...thanks!
b2binbad
Post by b2binbad »
I'm runnin the poly with 7 degree correction, energy suspension brand, and using the wild horses springs, progressive rate.
My little pony
Post by My little pony »
I put a set of rubber ones on and they only lasted one trip off-road, now that I'm putting a 4" lift on its all poly.
God forgives, Rocks Don't.
