4wd still not working did all the following
Posted: Thu Dec 10, 2009 8:47 am
				ok to start i went and took off the shift motor to see if it was froze up or not working, i put 12v to it and it barely moved then when i switched the polarity it worked both ways perfectly fine. I put it back on and still nothing, i got a new 4wd button cuz the lights never worked they did when u first start it but when it runs nothing. I checked the fuse under the hood and its good. Checked the fuses under the dash and there all good. Checked shift module box behind driver seat and then reset it a few times and still nothing, the only thing that happens is when you push either of the buttons you can hear it click behind the seat twice but still nothing.. Any ideas
