How do i remove rotors from 1988 bronco 2?
borjawil
Post by borjawil »
trying to replace the rotors on a bronco 2 1988, but i can seem to remove the rotors. There are rubber type caps that come out of the rotors. I think i need to remove these but not sure how to. Dont want to damage anything.
Re: How do i remove rotors from 1988 bronco 2?
take the caliper off and remove the lock nuts fron the outer wheel bearing and pull it off. done
forman621
Post by forman621 »
well if you take that dust cap off you can see a good size center nut that you will have to take off. then you will also need a special ford tool to get the slotted nut only has four slots. you might be able to use a punch or a screw driver. then evrything else behind that should slide of like a washer and there might be another threaded nut in there. the reason for this is that the bearings are part of the rotor and the whole thing is like one piece.
dont worry about the caps just take a screw driver to it and pound it a couple times.
good luck with whatever your doing
borjawil
Post by borjawil »
thanks guys. Just replacing the rotors and calipers.
