Tire breaker. Not fot the weak of arm.
Posted: Mon Nov 23, 2009 5:41 pm
				I made this to keep from paying some jack leg to do something I've been doing on tractors for years. All I have are a few tire bars so I neede a bead breaker:
The spoon is a piece of 3/8 x 2 flat bar I curved and burned an edge on. Welded the spoon to a peice of 1 inch square PTO shaft. The handle is a piece of 1 inch round PTO shaft with a bicycle handgrip on the end. I welded a 1 1/4 inch nut as a striker. When using my short handled 12lb maul, I ain't met a bead I couldn't break yet. Broke a set of tires on my tractor that have been on the rims since 1978 within 5 hits.
If you're a blacksmith, you'll have no problems. Otherwise prepare for a workout.
