wider axles
Posted: Fri Oct 16, 2009 2:38 pm
by OBXFHB
can i use wider axles from a bronco or 250 without cuttin. im not worried about laws its just a mudder. just want to know if i can do it without cutting and respline i dont mind it they stick out at least i wont roll this one over as easy
Re: wider axles
Posted: Fri Oct 16, 2009 3:31 pm
by Ranger Dave
yup, go with the full size ones
Re: wider axles
Posted: Sat Oct 31, 2009 8:26 am
by Rockcrawler
depends on what your doing. you cant put in a ttb in there but you can do a axle swap into them. There is no bolt in setup. Though it would be cool to see someone try to swap in a dana 50 ttb in there
Re: wider axles
Posted: Mon Nov 02, 2009 11:13 am
by OBXFHB
wat is ttb
Re: wider axles
Posted: Mon Nov 02, 2009 11:19 am
by OBXFHB
i will be using straight axles now im just looking for a donar truck with a drivers side drop on the front axle.
