I use my Bronco II for towing my jetski and on the way home
had no tail lights or dash lights. I checked my instrument panel illumination fuse and had no power at either side of the 10 amp
fuse. I do not have a fuse listed for tail lamps. HELP!
No tail lamp, dash illumination power
Re: No tail lamp, dash illumination power
Is there a manual online I can brouse?
If your B2 is 88 or 89 you can view my electrical diagrams. Just go to http://www.tekatlarge.com/Automobiles/RBVTEK.htm
There isn't a huge difference between the years.
That was a BIG HELP! Happy BII !!!!!!!!
Glad to help.
When that happened to my B-II (88), I was driving home through the mountains! It was the headlight switch that went bad. Easy fix, but nothing that I've tried will improve the brightness of the instrument lighting. I'd like to replace the bulbs with brighter ones, but don't know what to substitute.
