2.9 motor problems
Posted: Mon Aug 24, 2009 8:49 pm
by Broncopower33
I have an 89 bronco II with engine problems. I started with replacing the injectors, fuel pump, fuel fillter, maping sensor, and idle regulator. Checked the upper intake for leaks, no leaks, checked vacuum lines, pretty sure fixed all the leaks. The bronco is still having troubles starting on the first crack. Run's really ruff with the start up, it idle's at 1500 RPM, still has good power, doesnt matter if it is hot or cold, does not want to run ez. Any ideas would be great. Running out of parts to put on it. haha
Re: 2.9 motor problems
Posted: Thu Aug 27, 2009 3:29 am
by Ranger Dave
check the power brake booster for a vac leak??. the IAC could be stuck open causing the hi idle
Posted: Thu Aug 27, 2009 7:19 am
by Broncopower33
ok thanks, all look at that today.
Posted: Mon Sep 14, 2009 8:55 pm
by dowell
dude just run seafoam threw it...
Posted: Tue Sep 15, 2009 5:18 am
by Ranger Dave
Broncopower33 wrote:ok thanks, all look at that today.
well?
Posted: Sat Nov 07, 2009 8:11 pm
by oneway
dowell wrote:dude just run seafoam threw it...
:laugh:
Posted: Wed Nov 25, 2009 8:40 pm
by dowell
:laugh:
joke dipshit :wtf:
